Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Dvd player hook up
Author Thread: Dvd player hook up
Username: Way1954
I need help hooking up my new dvd player to my 3 year old Slyvania TV. The wiring seems to be okay but I can't get the dvd to play on the tv scteen. Any suggestions? I am not technically inclined. Could it be that I am using the wrong station on the tv?
Thanks
Username: Chitown
Post Number: 297
You probably have to switch the TV input from cable to to Input1 or input2 etc.
Username: Project6
Post Number: 3981
Where is your owner's manual?
Username: Jimvotaw
Encinitas, California
I have a really basic question. I have a Marantz SR7000 receiver and a Mistubishi 55905. When I hook a DVD player up. Do I go svideo and audio into the receiver and then the same thing out of the receiver into the TV?
Username: Samijubal
Post Number: 1647
You can, or you can just connect the player straight to the TV and the audio to the receiver. Then you won't need 2 s-video cables.
Username: Chitown
Post Number: 317
Jim use the Monitor out port on your receiver to connect to the TV and then get your sound full time from the receiver.
This way regardless of which device you use, DVD, Cable, DSS, you don't have to worry about changing anything on the TV.
Username: Marbilwil
Mount Juliet, TN
United States
Someone help me please!!!! I have just switched from Dish to Comcast cable. I have everything hooked up to surround sound. Everything was working fine before, but now, I can not get my dvd player to show a picture on the tv. I got a new one, a recorder, and I have tried everything. Before, I got the picture on channel 91. But with cable, I do not have a channel 91. I am getting sound just fine, but no picture. Anyone out there help me? Thanks.
Marsha
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Dvd player hook up [ « Previous ] [ Next » ]
