Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Yamaha YHT-360 vs 755?
Author Thread: Yamaha YHT-360 vs 755?
E4
Newbie here: I know the 755 comes with the changer and the 360 is a bit bigger in power, but I'm wondering if there are any other significant differences I should consider here -- 5.1 vs 6.1, having THX, etc. With the 755 package for $445 it's hard to ignore including the changer for just a bit more (vs 360's $350).
If you like the 360 better, can you suggest a changer?
This will be hooked up to a 34" Sony XBR. We watch 60% movies/40% TV, and listen to CDs as well. Thanks!
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Yamaha YHT-360 vs 755? [ « Previous ] [ Next » ]
