Thread: OVERLOAD |
New member Username: Woodytee
Mechanicsville,
Va
Post Number: 2 Registered: Apr-04
| Posted on Friday, April 02, 2004 - 09:02 pm: |
I'm very new to this, so I purchased a Panasonic A/V Receiver SA-HE70 100W x 5, paired w/ Jensen speakers for my daughters room. I only have a Philips 32" stereo TV hooked to it, yet after 10-15 minutes of my daughter using the system at a moderate level, the receiver cuts itself off and OVERLOAD flashes across the digital screen. Is it possible I have it hooked the wrong way or could it be something major. The system is very inexpensive, but it was just to entertain my daughter's friends in a 12 x 13 room. |
| Posted on Tuesday, May 11, 2004 - 02:19 pm: |
I have the SA HE200 with Bose Jewell cubes. I received the same message until I followed the manual and switched the setting to Low Impedance. You may have low impedance speakers 4-6ohms. Follow the manual on how to switch to the low impedance setting. The trouble shooting section of the manual will have other suggestions. |
| Posted on Tuesday, May 11, 2004 - 02:22 pm: |
You may also want to use the A speaker terminals only. The A&B settings are 6-8ohms. The A or B setting is 4-8ohms. |
