Home > Message Board > Home Theater > Bragging Area > ASHLEY HOME CINEMA
Author Thread: ASHLEY HOME CINEMA
Username: Thx_3417
Post Number: 1258
Well I said I’ll get some images of my small, but it’s not finished yet so the management is proud to present ASHLEY’S HOME CINEMA.
Note: three-screen “JBL CONTROL 5” placed across the front Note above centre channel is the JBL MR for the upper centre channel.
Note: JBL 4645 18inc 600watts continues program power down to 20Hz cut-off 80Hz sub bass Professional THX cinema approved.
The image is a bit dark sorry, anyway this is the right side surround JBL control 5 placed at the side back, in the middle is the Eltax HT-2Bipolar this is used for ambient surround matrix mixed down from the fronts.
The again just a little bit dark sorry, anyway this is the centre back surround JBL HT-1F this will produce a loud SPL db level up to 105db in the centre of the room.
The image is a bit dark sorry, anyway this is the left side surround JBL control 5 placed at the side back, in the middle is the Eltax HT-2Bipolar this is used for ambient surround matrix mixed down from the fronts.
Though a little bit unclear at the top is the SONY DVP-S336 DVD region 2 below it is the Pioneer DV-525 DVD region 2, below that is the Ferguson videostar Hi-Fi NICAM VCR not used as much now only for the odd film on VHS, and blow that is the Pioneer CLD-1750 Laserdisc player PAL / NTSC still in use, and lastly below that is the Pioneer CLD-2950 Laserdisc player PAL / NTSC again still in use.
This is the SoudLab 2WEX Active X-over for the centre channel this gives a bit more gain and increasing dialogue intelligibility further X- 20Hz to 500Hz to 20KHz 18db octave.
At the top is the JVC EQ this is for the split-surrounds, below that is the Marantz 1030 this is for the rear side split-surrounds, below that is the Marantz 1050 this is for the front centre channel, and the centre back surround channel, below that is the Marantz 1050 this for the front left and right mains each amplifier is for three-screen matching JBL control 5 and the for the centre back JBL HT-1F.
On top is the mixer that I have been using to do the LFE test, below that the Pioneer VSP-200 this used to produce two more extra ambient channels which comes from the fronts from the Kenwood KRF-X9050D THX select which is placed below, the Pioneer VSP-200 is Dolby pro-logic with auto balance, it got onboard amplifiers for the upper centre channel and the side middle ambient surround matrix, below the Kenwood KRF-X9050D THX select. Is the Yamaha DSR-70pro-logic this is used for the centre back surround with height surround ready, also the side rear split-surrounds, the pre-outputs from the Kenwood KRF-X9050D are going into the pre-inputs on the front Lt Rt to produce the signals with all output to separate EQ’s. and lastly at the bottom is the Yamaha DSP-100 this is used for taking the signal from the Active X-over Lf and HF outputs and the out puts to the amplifier.
Anyway there’s more to come….
Relevant Product Info
Username: Thx_3417
Post Number: 1260
Close up of the left side rear of the JBL control 5.
Close up of the right side rear of the JBL control 5.
Close up of the EQ’s including two “RTA” the other RTA is on the pc.
View of microphone face the front, for testing and calibration alignment.
This image shows the microphone, when calibrating the sound system with the use of an RTA.
Close up view of the JBL HT-1F centre back surround.
Username: Thx_3417
Post Number: 1261
Laserdiscs and DVD’s and more close ups of the JBL control 5…
Username: Thx_3417
Post Number: 1262
More close ups of the JBL 4645 professional THX cinema approved and dts millennium dts decode not in use as the Kenwood KRF-X9050D THX select as Dolby and dts digital decoding.
Close up of the JBL 2240H/ 18inc sub bass driver.
Note: millennium decode, above is a Teletex decoder.
Username: Thx_3417
Post Number: 1263
Username: Thx_3417
Post Number: 1268
Now showing “STAR WRAS” EPISODE 4 A NEW HOPE, the force is strong with the JBL 4645.
Username: Thx_3417
Post Number: 1271
A film for every mood, from Laserdisc to DVD’s/ Action, Musicals, Romance, Horror, Sci-Fi Documentary’s, Thrillers, True story events, just about enough to sink a battle ship.
Username: Thx_3417
Post Number: 1272
Username: Em69
Ottawa
Post Number: 24
Your wire management seems pretty good. I like the cardboard speaker holders as well.
Username: Thx_3417
Post Number: 1298
Username: Paul_ohstbucks
Post Number: 2288
Holy smokes andy....
That's a "LOT" of electronics. Thanks for sharing.
Ya know...
You really ought to consider putting your movies in alphabetical order!!!
You and I also share a similar taste in movies. I guess when you have that many, we're bound to overlap:-)
You should put an astrisk next to the description...."this setup is NOT for WAFfers".
Username: Thx_3417
Post Number: 1325
Paul
There’s titles like (20th century fox) films on the top shelf below that is Paramount and then “Columbia tri-star home video” (Universal) (Columbia pictures) (tri-star) below that “Buena Vista” (Disney) (Touchstone) which leads into (Warner Bros).
So I keep them in order to the Studios that produced them, and if I wanted to make it look a whole lot more entertaining, which would take a few hours to design, but figuring the space these films take up over “Laserdiscs” 1# being so affordable over there big brother or daddy, DVD’s multiply like bugs a before you know it, your surrounds by them, et the picture.
The home cinema is not finished as of yet, this is only temporary up front I’ll be building a baffle wall like in the Lucasfilm “THX” cinemas, this will extended the frequency response down lower on the three-screen matching JBL control 5 and the JBL 4645, which mind you already goes down to THX Quake levels.
Anyway glad you found it of some amusement and hope it was an eye opener to the seed of things to come………
Ashley
Username: Camaro823
British Colu...
Post Number: 214
I like your setup and your large collection (nice to see your not one of those woh own pirated copies of movies) Check mine out sometime its under the "My bascially done HT" thread.
Username: Thx_3417
Post Number: 1331
JC,
Cheers there’s no pirate copy’s in my home cinema set-up everything is legitimate, though it’s still under construction with lots a ideas like a “THX baffle” wall, about something tells me it will be a problem to install, I haven’t updated the images with any thing new reason is there no point, the positioning of the three-screen channels are placed in differently as to the images in my first post hear on the (Bragging) page.
Post Number: 2408
Any pirated copies would be lousy quality anyway. If you either have a good sound system or large screen, a pirated copy would look and sound like crap.
Username: Camaro823
British Colu...
Post Number: 215
Well thast not entirely true, there are programs out their that make duplicate copies of dvd's like DVD Xcopy. They make identical copies ( I know of people that rent movies and then burn it) Its more of a moral thing, and personally I find it stupid when people have a full library of pirated material. I will admit I have watched these movies and they are of identical quality.
Post Number: 2426
I disagree...
You're little $300 DVD burner cant reproduce the quality from the origional. If you had a 'real' soundsystem, you'll hear the difference.
Post Number: 2427
Also, screen size will make a difference. If you're watching the movie on your friends 27" in his mothers basement, you probably wont see a difference.
Now put that on a 10' screen or a large HDTV, and the differences will become more noticable.
Username: Camaro823
British Colu...
Post Number: 216
I agree screen size does make a difference and I assure you the difference is not noticeable,
I use this to watch my movies and they look great.
(the actual ones) and when my friends bring their movies over it looks identical. Not the best example, but my actual Napoleon Dynamite was identical to my friends burned one.
Username: Diverhank
Huntington Beach, CA
Post Number: 22
Regarding the topic of DVD copies versus original...I believe that the sound is identical. The video is somewhat inferior to the original if compression is required(--original size exceeds 4.7 GB which is almost always the case)
Username: Mysterio
Damn that's a lot of electronics! Love it! On a side note I don't buy bootlegs unless they are not in print or out of print like SPIDERMAN & HIS AMAZING FRIENDS or SILVER SURFER animated
Username: Thx_3417
Post Number: 1332
You bet, though this I only put together over the coarse of years, it’s one of affordability, and simplicity….
Although some of you will be turning on the wrong switch for all this, and though it’s not high tech, it does perform very well…
Username: Zorro
Post Number: 31
Hey Andy, this is impressive ! very well done Mate!
Hey, can you please tell me how to upload the Pictures? Everytime I try I get a message saying that the image is too big !
Thanks
Username: Thx_3417
Post Number: 1333
Zorro’
Take the picture that you what to be seen, and then upload it to the pc this will be saved on (hard-drive) which will be in (My pictures) folder, you will then enter (My pictures) folder and look for the image that you have save, once found right click over the image, and look for (edit) press edit this will enable you to, reduce the size of the image to within the correct size format, then save the image under a different name…
You will then be able to open the image and post this on the (Ecoustics) forums.
Also about edit there are some techniques that can be used to manipulate the image anyway Zorro’ hope this information is of some help to you…..
Username: Zorro
Post Number: 34
Andy,
Thanks a lot mate, I will try and see what happens
Username: Illuminator
Post Number: 1848
If you use a dual layer burner, it definitely can. I'm assuming you're referring to single layer burning in which the program has to compress the video so it will fit on the 4.7gb available thus reducing video quality quite dramatically.
Username: Camaro823
British Colu...
Post Number: 223
exactly
Username: Thx_3417
Post Number: 1334
Zorro’
Have you figured out how to upload your images yet?
Sure like to see your home cinema as well.
londonblue007
Personally, I watch my movies on a 40 ft wide cinema screen sourced from a long throw digital HD projector with a 32,000 watt 5.1 EV sound system powered by Crown Amps and sourced by a Apple computer into a Crest X4 Mixing console. But thats just me..... (I am the sound engineer at a college theatre, i can use it whenever i want)
so you like to spend a lot of your time talking dirty to men you ho mo
Username: D_singh
Post Number: 91
You know, there's a saying that says "Less is More". In this case, I think maybe it is.
Username: Oldschool4life
GOOD GOD!!!
...looks like a damn pawn shop.
:eek:
Username: John_s
Columbus, Ohio
US
Post Number: 703
You buzzards can fly around Ashley's old thread, but be advised the wise old sage has moved on to bigger and better things. Not much meat left here.
But, he still did it like that (this past year)...
...AND, bragged about it on sveral forums.
http://www.hometheaterhifi.com/forum/showthread.php?t=3102
Username: Thx_3417
Post Number: 1335
Yeah that’s right better things, the more things change the more they stay the same, and so you guys enjoy yourselves, and Mr “Shamu chef” we don’t need you trolling around on the “Secrets” and that’s not the only site that I’m joined to, follow me around and you won’t last long.
Ashley’ as spoken.
Username: Project6
Post Number: 5802
Indeed
Username: Mestre1966
Post Number: 20
DAMNNNNNNNNNNNNN
better not living next to me! lolllllll
You work for any demolition company or someting???
just for asking
price of all electronics was????
nice!!!!!!!!!!!!!!
Username: Dandandan
Brisbane, Queensland
Australia
Post Number: 30
wat was the price ?
Username: Thx_3417
Bournemouth,...
Post Number: 1504
Here is an update my small but Just bl00dy loud(JBL) home cinema.
"No, No you can’t possibly use x16 JBL control 1's for the surrounds!"
I’m still on schedule with the JBL control summer project, the plan is to install x16 JBL control 1’s for the surround array chain, so far just x8 are installed and up and running, truly awesome split-surrounds and the centre back surround is WOW, the height surrounds will be the next part of the upgrade, with a few more extra JBL control 1’s on the side walls.
I have taken a little “timeout” to read some back issues of the THX monitor to refreshing my memory with “THX Monitor” the professional monthly reading digest, the information is laid out clearly and in-depth over four pages, the part that I’m is surround loudspeaker layout, also the JBL cinema manual, I just like this stuff, its all good stuff!
Hears a photo view of “THX Monitor” volume 1, Number 4 February 1992, page 3
Username: Project6
Post Number: 9495
Oy, Ashley...got any HD-DVD or Blu-Ray yet:-)
Username: John_s
Columbus, Ohio
US
Post Number: 1061
Ashley....you keep adding speakers to that room and pretty soon there'll be no room for a decent sized HDTV you need.
Username: Thx_3417
Bournemouth,...
Post Number: 1507
Berny, John
Thanks
Only an affordable video projector will suffice! The impact with this amount of JBL Control 1 surrounds, and not forgetting it’s all been balanced and EQ, the results sounds more like what I would hear in a (cinema) plus it’s (future proof) so if I what to make any special adjustments all that I would have to here is a little re-wiring, and some re-plugging, no problem.
Username: Thx_3417
Bournemouth,...
Post Number: 1590
Here are some pictures from this summers JBL control 1 surround array project, these images weren’t placed here during the summertime because time and editing the sizes of the images so here they are.
The new JBL control 1 package price Ł49.95 UK, at “Richer Sounds” Hi-Fi home cinema store.
I first tried one of the JBL control 1 fitted to the centre part of the room, just to see what the performance was like. Well I was very impressed and the timbre balance wasn’t that far of ether, just a little bit equalizing will solve that.
Grandly over the weeks I placed them up, and angling them slightly downwards over the listening area and the whole surround started to REALLY come together as one whole superb surround effectiveness that wowed me!
Username: Thx_3417
Bournemouth,...
Post Number: 1591
Looking down the left JBL control 1, side surround array.
Username: Gamerdude
Ontario
Post Number: 199
wow amazing a NEW prospective of surround sound and that sub! Jesus! its a pig most likely sounds like a rock concert in there
good job
Username: Basshead86
Try Google
Post Number: 6757
this thread is ooooold. lol
nice setup Andy...Ashley:-)
Username: Thx_3417
Bournemouth,...
Post Number: 1594
Kyle, Muddy thanks
You should have heard it today, I mean feel it WOW "Drop Zone" 1994, what a cracking movie from start to end Foley wow you can feel the body punches!
Username: Thx_3417
Bournemouth,...
Post Number: 1597
Additional laserdiscs, that arrived today from the grand ole USA from a new best friend.
Blade Runner is the film of day! This early directors cut edition on laserdisc look very pleasing colours are rich and strong within the 2.35:1 Panavision frame, the neon lighting is beautifully captured on this laserdisc thou I would say the DVD will have a little more edge, but there is no way the VHS version would be able to measure up to this fine CAV edition.
The Dolby stereo soundtrack is what it is, it’s not the six-track Dolby stereo road show version that appeared on the 70mm prints. Dialogue is reproduced nicely via the JBL THX sound system with a cracking score that ends the film superbly with low end that slams into you’re chest!
Username: Deadhorse
Post Number: 22
I think this setup looks like a pawn shop and you can't possibly need six equalizers?.
Username: Thx_3417
Bournemouth,...
Post Number: 1598
Nick
Well you should check out some of the professional cinemas, the Dolby CP processor might use the internal 1/3 octave 27 band EQ for the in house use to match the frequency response within the ISO 2969 X curve! But some might have external EQ for custom modifications for certain films! Thus not tampering with the internal Dolby CP units EQ functions!
So yes I do need and I’m planning on changing them over to matching EQ m
