Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Newbie starting out
Author Thread: Newbie starting out
Username: Milcol
Have a Yamaha RXV2500 and thinking of the Polk CSi5 and RTi4 speakers and then add on in the future if needed any comments.
They are all really good. The only thing i would change is the rti4. I would go with something a little bigger to compliment the csi5. In any case Polk is the best and you will be happy with whatever you get.
Username: Project6
Post Number: 3736
What other speakers have you looked at and listened to?
Do you have a set budget or is it flexible?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Newbie starting out [ « Previous ] [ Next » ]
