Thread: Connecting two 1080i receivers to 1 tv with one 1080i input |
Unregistered guest |
| Posted on Saturday, August 27, 2005 - 07:56 pm: |
I have Mitsubishi HD TV that has only one 1080I input HD Direct TV box and a HD cable box - Can I connect both to the TV and get 1080I picture or do I need some type of a/b box? |
Silver Member Username: Chitown
Post Number: 281 Registered: Apr-05
| Posted on Monday, August 29, 2005 - 01:48 pm: |
By 1080i do you mean an HDMI connector? If so I don't see any other way but to use a a/b switch. Unless somehow you'd like to get a receiver with two HDMI input and one HDMI output. It is a very expensive solution.
New member Username: Goretro77
Post Number: 6 Registered: Aug-05
| Posted on Monday, August 29, 2005 - 02:06 pm: |
if you mean component 1080i I use the Audio Authority Auto switchbox, it accepts 5 sets of component video input and outputs to component cables. I did get it from smarthome.com but I did a search for it there so I can post the link and I did not find it now. I'm sur eit can be found elsewhere.... You can assign each set a priority. So I have my cable as the lowest priority and the second I switch on a dvd player/vcr the image from that source will be displayed instead of the cable. I like the manual override button on the front too so I can choose to have video from any given source playing on my tv and have my speakers pumping out music, the usual setup I use while a party is going on.... |
Gold Member Username: Paul_ohstbucks
Post Number: 2176 Registered: Jan-05
| Posted on Tuesday, August 30, 2005 - 01:58 am: |
You have both HD/Sat & cable? |
