Home > Message Board > Home Theater > Home Theater in a Box > RCA RT2250 Left and Right Speaker Ico...
Author Thread: RCA RT2250 Left and Right Speaker Icons are Flashing
Username: Jeliel
Greetings to all.
I hope someone can help me. I was given an Audio/Video Receiver (RCA RT2250) and this being my first Receiver and not being a connaisseur of such electronics (I'm a PC tech, but a nothing when it comes to A/VR)
> Now I tried the full set-up --> NO GO --> Left and Right Speaker Icons are Flashing
So I reduced it as much as I could to isolate the problem. I only have the power cord, right, left and SW speakers plugged in and tuned in to a radio channel.
So the radio is TUNED properly and I'm getting the channel, except theres no sound.
> Swapped speaker cable --> NO GO
> Swapped speakers --> NO GO
> Swapped speakers from a small audio system with built-in wiring --> NO GO
> Yes I RTFM :-) and followed all the instructions --> NO GO
> tried multiple online solutions I could find --> NO GO
I just can't get anysound. I succeeded in getting a little bit of sound from my CD player, but it was very low and extremely choppy.
So what does it mean when the icons flash and what can I do to make the damn thing work. I'm just dying to play my Matrix Collection :D
TIA for the help.
I HAVE THE EXACT SAME ISSUE! L and R speaker icons flashing in unison and no sound... did you get a fix yet? if so email me
mystereys
I have a similar problem here, with one change. Sometimes, instead of the sound cutting out all together, it cuts out in time with the flashing icons--so, 1 second of sound, 1 second silence, repeat. Really annoying. I've done everything except taking the thing apart and seeing if there's something wrong with the wires inside the unit. It seems as though this is a common problem.
rwainwright
I have the exact same problem with the same model receiver. Did anyone else find a solution?
O.O.T.P
try resetting to factory defaults ; you do this by pushing in sequence ; stadium;night;dspoff;club
Hello, I also have the same unit RCA RT-2250. I don't use it anymore because of the problem, but keep it. I found other leads to resolder some of the voltage regulators. That didn't help. I tried the reset mentioned above and I might be doing it wrong as I don't get the feeling is being reset. Could you expand on that.
Hi guswin95,
from the manual on page 9 :
Restore to Factory Settings
You can always restore all settings back to its original
state. When the receiver is in STANDBY mode, press
accordingly to restore all settings back to factory
default :
STADIUM -> NIGHT -> DSP OFF - > CLUB
here is the link for the entire manual :
http://www.rca.com/documents/RT2280_700610_25.pdf
good luck !
Pierre
Username: Rudie33
Hello Everyone.
Has anyone found a solution to this problem? Ihave the receiver and I hate to just throw it out, but it's drivin me nuts...
thanks
Rudie33
Username: Project6
Post Number: 7809
Throw it out or have it repaired or you will go nuts. :-)
The unit is broken and you cannot service it yourself.
Username: Rudie33
has anyone had it repaired? if so what did they say was the problem???? if it's replacing ic's or soldering I can handle that...
Rd33
Username: Cem
I have the same, infrequently works, often no sound, often sound comes and goes. Model RCA RT2250R. Can handle most repairs, need HELP finding the source to this problem.
TIA Chuck
Username: Arande2
Extreme SQ FTW
Post Number: 1771
This is one of the worst products I have ever seen from the large response that came about!
Username: Gavdawg
Upstate, New York
Post Number: 376
Andre, it is still better than the "white van" home theater speaker systems that create threads that are pages and pages long.
Username: Sandman71
After having the unit for 5+ years, this problem started happening to me. I bought a new DVD player, tried to use the optical input and boom, no more sound. Even with the old DVD player plugged back in (in the coax input), the sound no longer works and the left/right speakers are flashing. Does anyone have any ideas on how to fix this?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater in a Box > RCA RT2250 Left and Right Speaker Ico... [ « Previous ] [ Next » ]
