Thread: Cables - clips, plugs, or direct to binding posts? |
Bronze Member Username: Griffin_andrews
Post Number: 24 Registered: May-05
| Posted on Wednesday, August 17, 2005 - 01:19 pm: |
All, When hooking up all the various and sundry components...do you guys prefer direct / bare wire to binding posts...or, banana plugs (et al) into the posts. I'm curious if plugs are more cosmetic than anything else OR, do they prevent any nasty shorts etc. If you use "finished" cables...what brands EXCEPT monster (too pricey) do you lust for? Griff |
Silver Member Username: Philman
Richmond,
IN
Post Number: 120 Registered: Dec-04
| Posted on Wednesday, August 17, 2005 - 02:01 pm: |
Unless running high power Bananna's are ok and easy for high level of movement or room shuffling. I prefer unfinished, build your own. By far the cheapest way to get superior cables. Try Belden Cable #9716 (16awg), #9717 (14awg), #9718 (12awg) in the ZIP cord variety (portable) or 5200UP (16awg), 5100UP (14awg), 5000UP (12awg) for in-wall constructions. |
Gold Member Username: Paul_ohstbucks
Post Number: 1945 Registered: Jan-05
| Posted on Wednesday, August 17, 2005 - 02:30 pm: |
I think it's more personal preference and tied to your personal application. For example, I connect with bare wire into my speakers, but use the banana plugs to connect to my receiver. The only reason I did that was because my 12AWG wire wouldnt fit. |
