Thread: Xbox setup in theater |
New member Username: Rob1984
Post Number: 2 Registered: Dec-04
| Posted on Sunday, August 14, 2005 - 06:25 pm: |
I have a Samsung DLP, a Yamaha reciever, DVD player, cable box, and a vcr all hooked up. I have been plugging my Xbox into the vcr's front inputs (yellow red and white) and playing that way. I recently bought the Xbox HDTV AV pack and i cannot figure out a way to plug in the 5 inputs. Any ideas? |
Silver Member Username: Joe_c
Atlanta,
GA
Post Number: 953 Registered: Mar-05
| Posted on Sunday, August 14, 2005 - 06:44 pm: |
The "audio" comes through the RED and WHITE plugs, the video is called component video and hooks up with "y", "pr", and "pb" these will correspond with the component inputs on your TV. Depending on the receiver, you may have component switching and can hook it up through the rec. Good luck. |
Post Number: 3 Registered: Dec-04
| Posted on Sunday, August 14, 2005 - 07:15 pm: |
Well I understand how the plugs go, its just that I already have the vcr, dvd player, and cable box hooked up to the reciever and i cant figure out how to put the xbox in with all the other peripherals. |
Atlanta,
GA
Post Number: 954 Registered: Mar-05
| Posted on Sunday, August 14, 2005 - 09:12 pm: |
Use the tape inputs for sound and as far as the video goes, what other component video do you have? (hi def cable, dvd hooked with component?) |
