Thread: What receiver will fit me best ? |
David Bereznitskey Unregistered guest |
| Posted on Saturday, August 13, 2005 - 10:47 am: |
Hello all, i have read the threads and got some info about the receivers on the market. my front speakers are KEEF XQ3 and i want to know what receiver you recommand to get - i looked at these: 1. YAMAHA RXV2500 or RXV1500 2. Marantz SR7500 if you have other to reccomand, please do - in that price range, or even a bit higher. thanks, David |
Post Number: 3395 Registered: Dec-03
| Posted on Thursday, August 18, 2005 - 07:35 am: |
All of them are great receivers. It is all a matter of what you like. For myself, I like the Marantz. Others will like the Yamaha. You might like one or the other. I know it is no help to your dilemma, but you will be the one who will ultimately live with your decision. |
Gold Member Username: Paul_ohstbucks
Post Number: 1962 Registered: Jan-05
| Posted on Thursday, August 18, 2005 - 12:35 pm: |
I agree with Berny. I however would lean towards the Yammi. What you need to do is find a hifi shop with these models hooked up and listen to them in person, play with the remotes, go through the menus and setup procedures, and see which one you like the best. Only you can decide which you personally like better. All you'll get here are those who own Yammis saying "Yammi" is better(like me), and the same from Marantz fans. |
