Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Newbie needs a system for less than $500
Author Thread: Newbie needs a system for less than $500
Username: Ap0352
I've been looking at purchasing a home theater system with or without the dvd player without much luck.
I recently bought one of the Sony Dream series systems but it absolutely sucked! I returned it the next day.
I've had my eye on Onkyo's lately but wanted to check here for other's opinions. I'm looking to spend no more than $500 and the system also needs to be silver.
I'll be listening to more Audio CD's than DVD's if that helps any.
Username: Chatreez
Indianapolis, IN
If you like to listen to Audio CD, I'm not sure if it's the right choice to buy a HTIB. May be you should consider buying different of good pieces and pull them together. IMSHO
Username: Sic_deth
http://www.circuitcity.com/ssm/Pioneer-Surround-Sound-Receiver-VSXD515K-/sem/rps m/oid/115330/rpem/ccd/productDetail.do
http://www.circuitcity.com/ssm/MTX-12-Subwoofer-SW2-/sem/rpsm/oid/81414/rpem/ccd /productDetail.do
http://www.circuitcity.com/ssm/Sony-Bookshelf-Speakers-SS-MB150H-/sem/rpsm/oid/7 0204/rpem/ccd/productDetail.do
http://www.circuitcity.com/ssm/DCM-Center-Channel-Speaker-DCM16C-/sem/rpsm/oid/1 27518/rpem/ccd/productDetail.do
that will make a good start
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Newbie needs a system for less than $500 [ « Previous ] [ Next » ]
