Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Cannot Get Both Surround and Center S...
Author Thread: Cannot Get Both Surround and Center Speakers to Work Simultaneously!
Username: Pixels
I am setting up a Home Theater System and I have the following equipment: Philips DVD (DVP5500S) Player with 5.1 Channel output; a Luxeon LogicFox V5.1 with built-in Amplifier.
I made all the cable connections carefully but I cannot get both the Surround Speaker and the Center Speaker to play simultaneously. In other words, I can only get either the Surround Speaker to work properly or the Center Speaker to work correctly but not both! What is more problematic is that I can get the surround speaker to work if the cable at the other end is connected to the DVD Player’s Center output port!
Where might the problem be? What am I doing wrong?
Thanks for your help!
Username: Pixels
By Surround Speaker, I mean the Subwoofer.
Username: Feot
Texas
Post Number: 64
So you're thread should read like this?
Thread: Cannot Get Both Subwoofer and Center Speakers to Work Simultaneously!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Cannot Get Both Surround and Center S... [ « Previous ] [ Next » ]
