Thread: Maximum Lip Sync Delay to account for |
New member Username: Raks
Post Number: 8 Registered: Aug-05
| Posted on Saturday, August 06, 2005 - 11:38 pm: |
Hi, As per the research I did over the NET about Lip Sync Problems with HD, I am assuming it is a very needed feature in the receiver. Can anyone let me know what is the maximum Lip Sync delay (how many milli secs ) that we should be taking care of using a receiver's "Lip Sync Delay" feature ? Thanking you all |
Gold Member Username: Paul_ohstbucks
Post Number: 1877 Registered: Jan-05
| Posted on Sunday, August 07, 2005 - 02:32 am: |
I think you're barking up the wrong tree. There are lots of things to look for in a receiver, and what you mentioned isnt one to obsess over. Good luck... |
New member Username: Fnegroni
Post Number: 5 Registered: Aug-05
| Posted on Tuesday, August 09, 2005 - 08:15 am: |
I posted a reply in the other thread you started over at Home-Audio/Receivers |
Bronze Member Username: Fnegroni
Berkshire
United Kingdom
Post Number: 12 Registered: Aug-05
| Posted on Wednesday, August 10, 2005 - 08:01 am: |
Lip synch is an issue, which I think it is best resolved by buying a stand alone digital audio delay unit, which will give you more flexibility, and will let you choose the receiver you like without worrying about it. All recent Yamaha receivers have lip-synch delay built in. The maximum depends on your gear, mine requires 100ms at maximum, but some DVDs can push that limit to 160ms. |
Silver Member Username: Dmwiley
Post Number: 973 Registered: Feb-05
| Posted on Wednesday, August 10, 2005 - 08:30 am: |
Well Filippo Jabroni, sounds like you have your answer. |
