Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Component to DVI-D connector/converter
Author Thread: Component to DVI-D connector/converter
Username: Tonytiger
PA
US
Post Number: 112
Does anyone have any experience with a Component to DVI-D converter? My SONY Wega box has 2 component inputs, both in use. I have a 5 DVD player I want to hook up but the only available high quality input is DVI-D. The three othe inputs are only S Video. I would like to do this without adding a another input switch box. The Wega has a self contained switch for the 6 video inputs. A Google search found some 300-400US$ boxes but that seems high.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Component to DVI-D connector/converter [ « Previous ] [ Next » ]
