Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Optimum Setup for Samsung Home Theater
Author Thread: Optimum Setup for Samsung Home Theater
Username: Quesanova
Hi guys I recently purchased a 50' Samsung 5039 HD Plasma with a Samsung HTIB SK5 with standard DTV RCA receiver. The SK5 is a all in one unit w/5disk changer that plays DVD,CD,MP3...has digital tuner and Klisp speakers. I was not aware that the reciever did not convert video signals from different input meaning I can't run s-video in and composite out to the tv and get a signal. So i'm stuck with having the sat box run directly to the plasma from component a/v cables. My question to you guys is how can I optimize my picture quality while using the Samsung SK5. I will replace the RCA settop box for a more advance one if needed. Your feedback would be greatly apreciated.
Username: Quesanova
I meant s-video to component out to the TV, sorry.
Username: Two_cents
Post Number: 46
Running component cables directly from the sat box to your HDTV will get you the best picture quality. There's no need to run the video cables through the receiver. Just run the audio cable(s) from the sat box to the receiver and another one from the receiver to the TV. You should be able to enjoy your HTIB with this set-up.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Optimum Setup for Samsung Home Theater [ « Previous ] [ Next » ]
