Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > New sony home theater in a box
Author Thread: New sony home theater in a box
tookie7155
what are the comments/reviews on the new sony DAV-X1 home entertainment system ? and the sony DAV-FX10
tookie7155
sony DAV-FX10 comments / reviews? is this system worth it or not?
the trickster
here is a review for you
http://www.circuitcity.com/ccd/productDetailReview.do?oid=126338&com.broadvision .session.new=Yes&com.broadvision.session.new=Yes&BV_UseBVCookie=No
Username: Project6
Post Number: 3891
for that price you can do better.
Username: Dmwiley
Post Number: 1038
tookie, do your own research you lazy bum.
dales an a s s
dale go pull your little thing in the corner
The sound lacks everything. The Bose GS II is better, but the latest from Denon really impressed me!
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > New sony home theater in a box [ « Previous ] [ Next » ]
