Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Placement of Left and Right Channels
Author Thread: Placement of Left and Right Channels
Username: Dapercy
Post Number: 11
I'm stuck putting my rears on either side of the couch facing the TV. The center sits on top of the TV, but what is optimal placement for the left and right front channels? The TV is centered against the wall.
Should I push the left and right channels all the way to the edges of wall or should I put them half way between the center and edge of wall? Or is there some other optimal placement.
Thanks in advance for your advice.
Username: Dapercy
Post Number: 12
Come on, one of you audiophiles has to have an answer.
johndeereman
It's amazing what you can find with this internet invention thingy. http://www.dolby.com/consumer/home_entertainment/roomlayout.html
Username: Dapercy
Post Number: 14
That'll do johndeereman. Tried to google it up but didn't find that. Thanks for the find!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Placement of Left and Right Channels [ « Previous ] [ Next » ]
