Thread: Surround Sound Hookup |
New member Username: Ggreen
Post Number: 2 Registered: Jul-05
| Posted on Sunday, July 17, 2005 - 04:20 pm: |
I have an old Sony STR-DE515 "AC-3 Ready" Pro Logic Receiver. I have it hooked up to my DVD player via the audio cables, the DVD drives the TV display with a S vidoe cable. My question is, can the receiver process "Surround Sound" without a "AC-3 Ready" Processor? If I turn on the Surround Sound and select PRO LOGIC, is my configuration going to give me the proper sound? Thanks in advance for any help |
New member Username: Bama12
Loxley ,
Al
Usa
Post Number: 1 Registered: Aug-05
| Posted on Sunday, August 07, 2005 - 03:41 pm: |
i have a sony reciever b-m: son strde635 had a protector error comes up constantly what are we doing wrong ; plus our 2 small speakers in the back ground do not seem to put out the sound right[sounds like an echo ]can you help us. thanks for your help |
Post Number: 7 Registered: Jul-05
| Posted on Sunday, August 07, 2005 - 08:57 pm: |
I also get the protector error, usually after using the remote to change the volume. I've never been able to figure out why. I don't have the rear speakers in my setup (just the 3 in the front and the subwoofer). Its possible you don't have the Surround Sound mode set correctly, I always use Dolby when watching DVDs and turn the Surround Sound off (just stereo) when watching everything else. |
