Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Showing off
Author Thread: Showing off
Username: Stereo_genious
Hey guys, whazzup! Listen, I have one little question for you dudes. If you wanted to buy a surround sound stereo and you wanted one that you plan to impress teenagers AND audiophiles with it, which equipment would you recommend? In other words, the system would have to sound good to audiophiles, and pound out lots of bass when called upon to do so. What would you guys buy?
Username: Dmwiley
Post Number: 901
I would only buy a system that impressed me. Maybe you should ask some teenagers and audiophiles what they like and govern yourself accordingly.
Well, I did find these Cerwin Vega speakers with dual 15" woofers. I believe the model number for them is CLSC-215. Do you think these speakers would be worth showing off? Thanks
Username: Joe_c
Oakwood, Ga
Post Number: 581
they would work for the teenagers
Username: Joe_c
Oakwood, Ga
Post Number: 582
Hey Dale I got some Totem rainmakers friday, they sound friggin great.
How much are the rainmakers?
Correction: Can the rainmakers pound out lots of bass when called upon to do so?
Post Number: 13
What about the JBL e90's or e100's hooked up to a Marantz receiver? Will this be a good system to show off?
Username: Dmwiley
Post Number: 949
Joe, that's great. In my experience,Totems tend to be "Forest Gump" speakers-you never know what you're going to get. But when they are right, man they are right.
Username: Paul_ohstbucks
Post Number: 1656
Mike,
I suggest you audition speakers and choose the ones that impress you most.
Pretty simple, eh?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through August 18, 2005 > Showing off [ « Previous ] [ Next » ]
