Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Have Yamaha 7.1 AV amp, need advise o...
Author Thread: Have Yamaha 7.1 AV amp, need advise on speakers
hi,
i have just entered the world of home theatre and managed to acquire Yamaha RX-V650 AV recievr which is a 7.1 system.but the problem is i have not got hold of spkrs for it.kindly advise which 7.1 spkrs would go with the amp. my room size is 6mtr x 4mtr.which is small, and therefore need wall mounted satelite typespkrs and decent subwfr.i would be listening to all kinds of music and watch movies too on the same system . i have a 29" Sony wega flatscreen TV and pioneer DVD player to go with it.i am in India so availibility is a problem and would be seeking help of my friend in dubai to source the spkrs but carrying them would be inconvinient so a compact system requested.
kindly advise. my budget is about 600-700$.
regds
atmaram deshpande,Goa-India
Username: Joe_c
Oakwood, Ga
Post Number: 560
What brands are available to you???
almost all standard brands are available but are so costly that, prices in other countries are almost half. therefore i will be sourcing from Dubai, where rates are cheapest and i have my friend there who will bring them along with him in 2 months time.
Username: Joe_c
Oakwood, Ga
Post Number: 572
For that amount of money I would probably go with psb alpha's if you can get them or polf rt bookshelves if not.
Username: Joe_c
Oakwood, Ga
Post Number: 573
polk*
Polk Monitor 40 speakers are available in India for about Rs.10,000 a pair. This is a very fair price. You can also look at Acoustic Energy EVO Series that are available from Banglore for about 15,000 a pair. These are Stereophile recommended speakers and have won awards for 3 years continuously.
There are a number of Indian brands that are also very good for HT only. Lithos from Mumbai is only 11,000 a pair, very small, very musical and very good for HT also. Then you have Sanen, Thorvin, and a number of high end brands from Pune.
atmaram deshpande
can you give me locations of some dealers in pune whrer i can check out the speakers.however, as i said earlier i need 7.1 spkrs,pls give detailed breakup channel wise.
do we have Hsu research spkrs packages available in india?
atmaram deshpande
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Have Yamaha 7.1 AV amp, need advise o... [ « Previous ] [ Next » ]
