Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Dumb question
Author Thread: Dumb question
goofball
how do you get audio from a standard a/v receiver into 5.1 analog inputs
the pre-amp outputs?, what is pre-amp, i'm so confused
Username: John_s
Columbus, Ohio
US
Post Number: 26
goofball:
Please state your problem clearly. What is your desired end result? What is your equipment?
goofball
I was wanting to know how to get ac-3 and dts processed audio out of a decoder and into a seperate device that has 5.1 inputs
the reason being that i don't want to use the speaker hook-ups on the decoder, but the speakers on a seperate audio system that has 5.1 inputs
Username: John_s
Columbus, Ohio
US
Post Number: 27
If your "decoder" has neither 5.1 line outputs (6 in all) for the decoded audio signal, nor an optical or coax output for the undecoded audio signal, then you have a problem that's beyond me.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Dumb question [ « Previous ] [ Next » ]
