Thread: Grounding problem or just EMI need advice |
Unregistered guest |
| Posted on Friday, July 01, 2005 - 10:01 pm: |
I have completed the instalation of my home theater system (thanks to all on this site that provided equipment reviews and recommendations) After getting everything hooked up it appears I am getting what looks like a 60 cycle roll on the plasma. The system goes like this; from the wall cable (Time/Warner) into the HDTV/DVR cable box Component Video out to Yamaha RXV2500 Yamaha component video out to smarthome wall module (RCA to BNC) Broadcast grade Component cable extends 40 ft. cable into the back of another smarthome wall module BNC to RCA Component video cable to Panisonic TH50PHD7UY All components are on the same electrical circuit. Mag Clamps everywhere. Equipment rack and components grounded. any suggestions would be GREAT!!! I am so close. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4321 Registered: May-04
| Posted on Saturday, July 02, 2005 - 12:52 pm: |
Well, you're probably not going to like the answer I have. It is unlikely anyone could guess where your problem stems from. The best solution I have for you is to unplug each component, one at a time, until you notice the problem diminish or disappear. Trial and error is the best route at this point.
Silver Member Username: Philman
Richmond,
IN
Post Number: 114 Registered: Dec-04
| Posted on Saturday, July 02, 2005 - 10:44 pm: |
Follow Jan suggestions, but give a heavy notice to your cables. 60hz noise can enter through poorly shielded cables (ie Cheap ones) or poorly terminated coax. As you go through the process of elimination try substituting cables, if you have em. |
Dallas,
TX
Post Number: 4342 Registered: May-04
| Posted on Sunday, July 03, 2005 - 02:14 pm: |
Very good advice. Some cables are directional in that they will only have the shield terminated at one end. If the cable is installed incorrectly, you can have some problems with 60Hz noise entering the system. Older cables could also suffer from a deteriorating shield if they have been bent and twisted into a severe position.
