Thread: Hooking up outdoor speakers but need more power/inputs |
MagnusDM Unregistered guest |
| Posted on Friday, July 01, 2005 - 04:17 pm: |
Hi everyone. I’m new here and know hardly anything about home theatres, the electronics, or the speakers. My problem is that I need to hook up 4 outdoor speakers somehow to the CD player that is inside my house part of my home theatre but when I look at my amp/receiver I don’t have enough places to hook up the speakers without splitting the connections. My home theatre right now consists of: ELECTRONICS: 1. DVD Player - Sony DVP-S7700 2. VCR - Sony SLV-999HF 3. CD player - Sony CDP-CX400 4. Receiver/Amp - Sony STR-V444ES 5. Power Centre - Monster Power - HTS 5000 6. Satellite - Bell Express Vue 7. Satellite - DirecTV 8. TV - Sony KP-65XBR10W SPEAKERS: Centre - Boston Lynnfield VR Series - VR920 Front Left/Right - Paradigm Reference Series - OM-520 Rear Left/Right - Boston Designer Series - 336pt (in wall) Sub - Paradigm - can’t remember model All of the above stuff is in one room and I am looking to be able to connect 4 more speakers that would be outside to the same equipment so that if I wanted to I could play the same CD in and outside at the same time. Any help of what I need to make this work would be helpful.
Gold Member Username: Paul_ohstbucks
Post Number: 1524 Registered: Jan-05
| Posted on Friday, July 01, 2005 - 04:25 pm: |
Buy a 2nd receiver to run the outside speakers Good luck........ BTW, you dont want to mess with splitting connections buy plugging multiple speakers into the same port. OUch..... |
| Posted on Friday, July 01, 2005 - 04:39 pm: |
can i do that? can i connect 2 receivers together? |
Post Number: 1531 Registered: Jan-05
| Posted on Friday, July 01, 2005 - 05:01 pm: |
It depends on the reciever. If anything, you're looking at either replacing your main receiver with one that can do the job, or running two separate systems.
| Posted on Friday, July 01, 2005 - 05:36 pm: |
Can I not just get a pre-amp or something like that? Can't I hook a pre-amp into my current amp/reciever to power the new speakers and somehow tie it in with all my other equipment? |
