Thread: DVD Picture problems |
| Posted on Sunday, March 14, 2004 - 06:37 am: |
I have a Toshiba 42H83 HD projection TV and a Yamaha DVX-S60 Home Theater System (built in DVD player). When i tried to play a DVD i rented, the colors on the screen are all washed out (sort of like a film nagative effect). I tried other DVD's I have watched in past but have same problem with them now. I have had system for 2 months and watched may DVD's with no problems untill i rented this DVD. Any ideas about what might cause this effect. Thanks! |
| Posted on Monday, March 15, 2004 - 07:34 pm: |
Bill, how is your dvd player hooked up to the tv? Check your connections to see if any are lose. If your using the R-G-B connections and one is lose, you'll get the effect your describing. |
Unregistered guest |
| Posted on Saturday, March 20, 2004 - 04:31 pm: |
I have an lg dm4941p dvd player. I have rented 3 dvds - the first and third had the same problem, namely that the picture keeps cutting out and the screen goes blank. This happens throughout the movie, for some seconds at a time. Yet in the dvd shop the same movies play ok. |
Silver Member Username: Project6
Post Number: 383 Registered: Dec-03
| Posted on Saturday, March 20, 2004 - 09:40 pm: |
very good chance it's the dvd player, I'm thinking you've checked the integrity of the cables and connections?!? |
| Posted on Friday, May 07, 2004 - 06:12 pm: |
i have an lg dm4941 dvd player, i have recently found out it plays only zone 2 movies... is there any chance of hacking this, or am i supposed to put in a chip? |
| Posted on Wednesday, June 02, 2004 - 06:41 pm: |
I have a JVC SV-S65 DVD/CD player that until recently worked well. Out of the blue the picture was diagonal lines. Audio is fine. Bought a new S video cable, checked connections, all tight, still have the problem. Any suggestions? |
Bronze Member Username: Jdsaenz1
Post Number: 28 Registered: Jun-04
| Posted on Thursday, June 03, 2004 - 09:50 am: |
I know this is old school, but just to make sure: have you tried connecting via standard rca-type video cable to see if the same problem exists? |
