Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Need help wiring cable TV to home the...
Author Thread: Need help wiring cable TV to home theatre
Username: Camaro823
British Colu...
Post Number: 17
Hey I am really new to home theatre. I got a whole system ready to go. I hav a sony all-in-one home theatre (yes i know its not that good but i got it for free). I have no clue how to hook up the system though. I have the DVD hooked up and that works fine. Can anyone tell me what do I hook up to make the cable tv work through the home theatre ?
Username: Daedilus
Post Number: 158
in general hook the video and audio output of the cable box into the ht receiver.
then run the video monitor out to your tv set.
if you post model numbers of the equipment i can get a tad more specific.
Username: Camaro823
British Colu...
Post Number: 20
Thanks for the input,
I don't have a cable box, its just the cable from the wall.
Model Numbers
Hitachi 51F510 (TV)
HT-DDW760 (Home theatre in a box)
STR-K760P (Receiver it came with)
Thanks for the help
Username: Daedilus
Post Number: 161
Your tv doesnt have a digital audio out, so your going to have to hook analog audio from the tv's variable audio out to the tv analog audio in on the receiver.
Being as you have an HDTV monitor, you might consider getting some HDTV to watch on it by getting an HD cable box.
Then you could hook up the cable boxes digital audio out to the receiver and enjoy an hdtv picture with digital surround sound.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Need help wiring cable TV to home the... [ « Previous ] [ Next » ]
