Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Which Screen for my projector should ...
Author Thread: Which Screen for my projector should I get?
Username: Ezduzit
I am buying a Hitachi Home-1 Projector. Do I want a Matte White, High Contrast Grey or beaded glass screen?
I have good light control in the room with very little natural light from one exterior door in the basement.
I am planning on getting a 106" viewable screen (52" x 92") and will use this with mostly DVD movies or possibly HDTV Satellite down the road.
Thanks for any input.
Ask for recommencation from the screen manufacturer.
Scottro
Ron, in this review of the Home-1, the author recommends a higher gain screen of about 1.3, so I suppose the H/C grey or glass bead would be the way to go.
http://www.hometheaterhifi.com/volume_10_4/hitachi-home-1-projector-12-2003.html
There are also a lot of great informational articles on getting started into projection on projectorcentral.com.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Which Screen for my projector should ... [ « Previous ] [ Next » ]
