Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Help me I've Got no idea at all
Author Thread: Help me I've Got no idea at all
Username: Nonuffing
Porirua, Wellington
New zealand
I've got a Pioneer receiver VSX-D912-S/-K and 4 speaker boxes things (1000mm h X 500mm W X 500mm L) each with 1 12inch sub and 5inch mid range and a tweeter thing. I have it all hooked up to my computer just 4 playing music really loud. But cos they r all facing me is there anyway to setup without surround sound but using all of the speakers at full noise.
Username: Daedilus
Post Number: 40
yes set your system to 6 channel surround.
here is your manual:
http://www.pioneerusa.com/pio/pe/vgn/images/portal/cit_11221/50199operating_inst ructions_VSX-D912_2003411954183030.pdf
Username: Nonuffing
Porirua, Wellington
New zealand
i did that but all the speakers dont have the same output?? some are quieter than others and its not the spaekers?
Username: Daedilus
Post Number: 41
My mistake, i typo'd... i meant put your system in 6 channel "stereo", not surround..
set your system to 6 channel stereo, for all sound even out of all speakers.
I've got the same Model VSX-D912-S but I'm searching for the best speakers for this. Can anyone who had an experiences which speakers would be the best to connect to this?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 14, 2005 > Help me I've Got no idea at all [ « Previous ] [ Next » ]
