Thread: Simple Connection Problem? |
| Posted on Tuesday, March 09, 2004 - 07:56 pm: |
I just moved and I am setting up my system again. I have a digital cable box, 36 in Sharp TV (2 sets of analog connections and 1 s-video) Kenwood Kf-309 receiver and JVC DVD palyer)I have the DVD hooked up perfect. I cannot hook up my TV through the receiver to hear what I am watching. I thought it would be simple running the RCA cables in the audio out of the TV to one of the video or monitor audio in connections on the reciever, but no luck none of them work...Please help!
Relevant Product Info
Silver Member Username: Project6
Post Number: 337 Registered: Dec-03
| Posted on Tuesday, March 09, 2004 - 09:26 pm: |
have you configured the TV to send out audio signals? go to menu, audio set-up, fao=on |
| Posted on Tuesday, March 09, 2004 - 11:04 pm: |
In my TV Audio Setup menu there is only a slection for Stereo, SAP or Mono...and a selection for Equisound for keeping the TV at the same volume level as well as a selevtion for internal speaker on/off. |
Bronze Member Username: John_s
Columbus,
Ohio
US
Post Number: 18 Registered: Feb-04
| Posted on Wednesday, March 10, 2004 - 10:28 am: |
I would run audio to the receiver directly from the R/L line outputs of the cable box. That way, you can use the TV speakers alone for casual viewing, or use your external system and hear true stereo. (The RF converter in most cable boxes usually strips the MTS stereo signal to mono via the VHF coax output on channels 3 or 4.) |
| Posted on Tuesday, April 27, 2004 - 09:14 pm: |
I have a Durabrand HT-400 system. I feel like I have it connected correctly but there's no sound coming from the speakers. No static-nothing. Is the whole system shot? |
| Posted on Thursday, April 29, 2004 - 03:49 pm: |
I have a Yamaha receiver with Bose speakers. I have hooked up my DVD, VCR and cable box and there is no problem. However, I am unable to record programs from TV. The VCR output jack from the receiver is connected to A?V input of the VCR. Is there anything else I need to do? |
Columbus,
Ohio
US
Post Number: 93 Registered: Feb-04
| Posted on Thursday, April 29, 2004 - 08:26 pm: |
Kyle: First, do have an audio/video feed going into the receiver from the cable box? Second, if so, then you must switch the VCR to its line input so it will recognize the signal coming out from the Yamaha. This input is usually found one click down from channel 2 on the VCR. |
