Thread: Surround not workin with tv. |
New member Username: Gordon24
Post Number: 1 Registered: Jun-05
| Posted on Wednesday, June 08, 2005 - 06:10 pm: |
i have a sony dvd home theater system. the surround sonud works when i play dvds but not wen i watch tv.sound only comes out of 3 speakers and the sub.i am using comcast digital cable with a scientific atlanta explorer 2100 cable box.and a jvc tv. does anybody know how i can get all 5 speakers working when i watch cable? |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 355 Registered: Mar-05
| Posted on Wednesday, June 08, 2005 - 07:07 pm: |
watch a program with dd5.1 or prologic and make sure you have either pro logic setup in the rec. settings or make sure the audio connection between the cable and rec is (ideally) optical or coax digital or second best l,r rca's. p.s. most programs on tv are not 5.1 and even the ones that are prologic rarely have rear sounds, commercials tend to have more surround than main programming.
New member Username: Daedilus
Post Number: 10 Registered: Jun-05
| Posted on Saturday, June 11, 2005 - 12:23 am: |
further make sure you own a true 5 channel amplifier, not merely a pro logic amp which steals power from the front speakers and sends it on a delay to the rear. Most theater in a box systems are pro logic, not DTS. |
