Thread: Crackling noise?????? |
New member Username: Bose_boy
Post Number: 6 Registered: Mar-04
| Posted on Monday, March 08, 2004 - 05:30 pm: |
When Im watching TV,all the sudden it will make this annoying loud huming/crackling noise..then stop,then start again..Mainly on movie channels. |
Bronze Member Username: Disco_stan
Post Number: 80 Registered: Dec-03
| Posted on Tuesday, March 09, 2004 - 12:32 am: |
Are you using a Digital Optical cable from your dvd to you main source? Either the dvd is dusty or you digital cable needs cleaning or you need a new one...buy online to get the best deals. Here are some links: http://www.nextag.com/All~optical+audio+cablesz0zB4zttz5-htm go on ebay and do a search; "digital optical cable" and there should be a bunch listed if you do mind to shop on ebay. Theres my "Two Cents" hope that somewhat helped you out. |
Post Number: 7 Registered: Mar-04
| Posted on Tuesday, March 09, 2004 - 02:39 pm: |
I got a digital optical cable hooked to my DVD player,going to my stereo. The noise is on the TV channels coming through my system. |
Post Number: 81 Registered: Dec-03
| Posted on Tuesday, March 09, 2004 - 06:42 pm: |
Well you are not going to the best sound quality from a tv broadcast reception. Maybe your your cables coming from you sat/cable source to your stereo are not shielded. Shielded cables do make a difference. |
Post Number: 9 Registered: Mar-04
| Posted on Tuesday, March 09, 2004 - 09:15 pm: |
Oh,the actual audio cables im using from the tv to the Stereo are junky ones from wal-mart..But for the DVD player I got Component wires,and the Digital for audio. Will the audio cables make a difference in sound for just normal tv,or mainly the shielded part is what their desired for? |
Post Number: 85 Registered: Dec-03
| Posted on Tuesday, March 09, 2004 - 09:39 pm: |
Im not too knowledgable about cables, but from what I read yes, better the cables, better the profromance to a certain extent. But I dont want to give you any wrong information so check out this thread: http://www.ecoustics.com/bbs/messages/1/13749.html and I'm sure it may help you out. |
