Thread: Help Receiver not Decoding Digital |
Zak2355 Unregistered guest |
| Posted on Monday, June 06, 2005 - 04:17 pm: |
Hi, I have a Sony DE1075 6.1 Channel Receiver and it recently started not decoding digital. I have an optical cable hooked up from the DVD to the receiver and it has worked in the past. I did configure all the DVDs to DD and still it only goes to prologic. It says 48kmz PCM doesnt digital have to be 96? and if so how would i change it back or can a cable go badly? If anyone could help it would be much appreciated. |
Silver Member Username: Dmwiley
Post Number: 745 Registered: Feb-05
| Posted on Monday, June 06, 2005 - 04:56 pm: |
Yes optical cables can be damaged. Try the coax digital output (if your DVD has one). You can do this temporarily by using a standard rca cable-almost every one has some of these lying around. If no coax output, you may try replacement of optical cable, but make certain you have return privileges. |
zak2356 Unregistered guest |
| Posted on Monday, June 06, 2005 - 09:42 pm: |
Well I went and bought a new Optical Cable but it still doesnt work. Has anyone heard of a decoder failing? |
Post Number: 748 Registered: Feb-05
| Posted on Tuesday, June 07, 2005 - 07:57 am: |
Try setting your DVD to Dolby Digital output and not PCM output. |
| Posted on Tuesday, June 07, 2005 - 01:35 pm: |
Ty very much for your help it was much appreciated. IT was the DVD player. I dont know how it got switched. I was ready to go and buy a new receiver. Again thank you very much.
Post Number: 757 Registered: Feb-05
| Posted on Wednesday, June 08, 2005 - 01:58 pm: |
Great news. Enjoy. |
