Thread: Piecing together home theater system |
New member Username: Bhill2
Post Number: 1 Registered: Jun-05
| Posted on Thursday, June 02, 2005 - 12:10 am: |
I am looking to put together my own home theater system as opposed to buying a system in the box. One thing that I am confused about is the wattage of speakers compared to the wattage of the reciever. If I am looking at front left and right speakers that have a max peak of 400 watts does this mean that if I do not have a reciever that devotes at least 400 watts to each channel the maximum capabilities of these speakers will never be reached? |
Silver Member Username: Dmwiley
Post Number: 718 Registered: Feb-05
| Posted on Thursday, June 02, 2005 - 01:44 pm: |
Don't consider based on peak wattage. |
Post Number: 2 Registered: Jun-05
| Posted on Thursday, June 02, 2005 - 11:42 pm: |
what should my consideration be based on then?
Gold Member Username: Paul_ohstbucks
Post Number: 1034 Registered: Jan-05
| Posted on Saturday, June 04, 2005 - 06:47 pm: |
How about a budget? Are you planning on running a 5,6, or 7.1 setup?? Speaker wattage specs mean absolutely nothing, nor do they have anything to do with speaker quality. Speakers are blown by Amps sending clipped(distorting) signals, and not because they're being sent too much power. |
