Thread: Looking for an amp Not sure what to get |
New member Username: Jr66
Post Number: 1 Registered: May-05
| Posted on Monday, May 30, 2005 - 08:02 pm: |
Hi all, hopfully i can get some feedback. Im looking to get a new 7 channel amp for my H/T Ive done some research and really dont know which direction to go in. Im running the following system Denon 4802r Receiver, Denon DVM 4800 DVD player Paradigm Studio 100's which i love Paradigm cc 570 front and cc 470 rear aswell as paradigm adp 470 surrounds all are version 3, My sub is Paradigm pw 2200. i thought i would list everything as im sure some amps dont work well with some speakers and receivers. Thanks for your time
Kahanamoku Unregistered guest |
| Posted on Sunday, June 05, 2005 - 07:00 am: |
just make sure you dont plug in speakers that need more power than your amp can provide, and vice versa. I'm talking in regards to Wattage, as well as Resistance (ohms). 4ohm speakers on an amp that can only drive 6-8ohms will push your amp too hard, and at the very least, shorten your amp's life. as for wattage, just make sure you either match your speakers RMS to that of your amp, or have your speakers just that little bit higher, so that you dont blow them up if you accidentally turn your amp up full. |
