Thread: Onkyo Digital Sound? |
New member Username: Mrbrownsbooks
Post Number: 1 Registered: May-05
| Posted on Monday, May 30, 2005 - 10:32 am: |
Hello- I hope you guys can help me! I have just bought, and set up a Onkyo HT-R8230 home theater system, but I can not get it to do DTS. The only thing i get is Prologic II. I am using a monster cable digital coax cabel from my DVD to the receiver. Does anyone know what my problem may be? Im lost! Thanks |
New member Username: Yooper
Post Number: 1 Registered: Jul-05
| Posted on Thursday, July 07, 2005 - 08:21 pm: |
hello Josh, if you stii need help email me. I have the same unit. it is a little tricky.
Gold Member Username: Paul_ohstbucks
Post Number: 1614 Registered: Jan-05
| Posted on Saturday, July 09, 2005 - 09:50 pm: |
Josh, You need to go into the DVD player setup menu and activate DTS and 5.1. Plus, you need to verify that your DVD souce is recorded in DTS. In other words, if the source is recorded in standard DD5.1, it will not output in DTS format. |
Unregistered guest |
| Posted on Sunday, October 02, 2005 - 11:56 pm: |
Hello, I am thinking of buying HT-R8230. What's your take? I am novice in this area? which is the best DVD player that gels with this system? thanks |
