Thread: I'm not sure how to do my back speakers? |
New member Username: Kriscad
Fayetteville,
TN
Post Number: 5 Registered: May-05
| Posted on Saturday, May 28, 2005 - 06:38 pm: |
I need suggestions - just confused on the back speaker locations. I have this half wall behind the seating, not sure if I need to wire the half wall on top in the middle for a speaker or put two speakers on the back wall. http://ndesigns.net/room/new/ I need to make a decision before I start painting. Thanks-
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 3837 Registered: May-04
| Posted on Saturday, May 28, 2005 - 06:59 pm: |
Two speakers on the back wall, please. |
Fayetteville,
TN
Post Number: 6 Registered: May-05
| Posted on Saturday, May 28, 2005 - 07:16 pm: |
thanks- what brand - model do you suggest? |
Dallas,
TX
Post Number: 3838 Registered: May-04
| Posted on Saturday, May 28, 2005 - 10:18 pm: |
That's up to you. Buy the ones you like that sound similar to the rest of the speakers in your system.
zepplongfellow Unregistered guest |
| Posted on Sunday, May 29, 2005 - 06:19 pm: |
http://www.dolby.com/consumer/home_entertainment/ roomlayout.html http://www.dtsonline.com/consumer/technology/technical_literature.php Here are two links too a wealth of Knowledge. |
Fayetteville,
TN
Post Number: 7 Registered: May-05
| Posted on Tuesday, May 31, 2005 - 12:40 am: |
Thanks Zepp |
Silver Member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 151 Registered: May-05
| Posted on Tuesday, May 31, 2005 - 07:43 am: |
Kriscad Hallo there Bring the sofa forward so that you will get a 3 dimensional sound! That’s way to close to the back and if at possible place some more surrounds at the back to fill in the hole in the bucket! Ashley.
Bournemouth,
Dorset
United Kingdom
Post Number: 152 Registered: May-05
| Posted on Tuesday, May 31, 2005 - 07:48 am: |
