Thread: Help...no sound from Subwoofer |
New member Username: Clivep
Post Number: 1 Registered: May-05
| Posted on Tuesday, May 24, 2005 - 10:09 pm: |
Someone please help. I have a Sony STR-DE675 Receiver and Nuance speakers. Recently I noticed movies not having the same thump that they once had (after a re-arrangement of equipment). Check the speakers with a THX optimizer, I found that no sound was coming from the subwoofer. In my setup, the subwoofer is on (as per Sony's recommendations). Is there something wrong with my receiver, or is my sub blown? |
Silver Member Username: Paul_ohstbucks
Post Number: 960 Registered: Jan-05
| Posted on Wednesday, May 25, 2005 - 01:17 am: |
Most likely, something didnt get hooked up right when you rearranged your equipment. Double check your connections, and receiver settings. |
Post Number: 2 Registered: May-05
| Posted on Wednesday, May 25, 2005 - 09:06 am: |
Hi Paul, Thanks for the tip. I double checked everything...the sub is just connected via the low frequency cable, out from the back of the amp and into the right channel of the sub...this same setup worked before...any other help? |
Silver Member Username: Dmwiley
Post Number: 684 Registered: Feb-05
| Posted on Wednesday, May 25, 2005 - 10:05 am: |
Some subs recommend using left channel for mono input. Try switching it. |
Post Number: 3 Registered: May-05
| Posted on Wednesday, May 25, 2005 - 10:40 am: |
Hi Dale, I believe I tried that, to no avail, but I will go home tonight and check again. Thanks. |
Post Number: 962 Registered: Jan-05
| Posted on Wednesday, May 25, 2005 - 12:28 pm: |
Make sure that it has power, and go into your receiver menus to verify that the sub is activated. If that doesnt work, I'd suggest finding another sub to connect to verify whether the problem is your reciever or sub. When your friend or family member brings their sub for the 'test', have them bring their cable too. Either that, or take your sub/cable to someone elses house to connect to see if it works. Good luck |
Post Number: 4 Registered: May-05
| Posted on Monday, May 30, 2005 - 03:39 pm: |
UPDATE: I took the sub into the store, and they tested it there...they said the Amp is blown and will be replaced...then they tried to sell me an upgraded woofer...I just said fix the one I have now! Thanks for the advice though. |
| Posted on Saturday, June 11, 2005 - 09:20 am: |
Folks, System: Yamaha RxV 450 receiver Jamo E 570 Front Speakers Wharfdale Diamond Sw 150 SubWoofer (Most recent addition) When I connect the sub to the receiver's subwoofer-out jack, I get no sound, just a loud hum from the Woofer. Don't know what's wrong, either on the amp, or the woofer side. The manual says that when you switch on the 'Auto Power' button of the Sub, it would glow red if there's no signal, and green if there's a signal. In my case the light always glows red. Don't know what could be the probelm. The connection to the woofer is a single RCA line to the left line-in of the woofer. I've tried various crossover frequencies but to no avail, and different phases too. The phases in the Sub are 0 and 180, and the setting in the Amp is Phase rev, and Phase Norm. Different combinations have yielded no results. The Bass out on the amp is set to both--low frequencies go both to the sub, and the front speakers. As you might've noticed, I don't have any surround speakers. Is that any problem? Please help.
Bronze Member Username: Daedilus
Post Number: 16 Registered: Jun-05
| Posted on Saturday, June 11, 2005 - 10:51 am: |
Usually a steady pitch hum from the subwoofer indicates that the cable feeding it is unplugged and touching something grounded. Double check your cable and make sure that it is plugged into the Subwoofer output and not a tape or monitor output. After consulting your manual for your receiver i notice that the composite video monitor output is right next to your subwoofer output. Make sure that you are plugged into sub woofer output and not the composite video monitor out, or possibly even the EXT IN subwoofer input. http://www.yamaha.com/yec/customer/manuals/PDFs/RX_V450_.PDF For a further test unplug the subwoofer cable from the receiver entirely and see if the hum goes away, then touch the tip of the cable with your thumb, you should hear a hum each time you touch it. |
