Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through June 13, 2005 > New to home theatre. 5.1/6.1/7.1?
Author Thread: New to home theatre. 5.1/6.1/7.1?
Username: Matt_maglieri
Hi, I am purchasing my first "real" home theatre in a few days. I just recently purchased an Athena Micra 6 5.1 speaker system. I still have to pick out an reciever in the next few days.
I have two older KLH floor speakers with the following specifications that are not being used:
Maximum input: 290 watts
Minimun/ Maximum RMS: 3-150 watts
Woofer: 12" Polymer
Midrange Hemi-Dome: 4"
Tweeter: 1" Soft Dome
I have my reciever narrowed down to the Yamaha 6.1 5850S and the Sony 7.1 STR-DE697. Up until now I was planning to just use the Yamaha with my new Athena speakers, but then I thought about my two old KLH speakers and came across the Sony 7.1
How do you recommend I setup the room? Do I use the Athena 5.1 system by itself? Use one of the KLH as a rear speaker on a 6.1 system? Or use both of the KLH's on the Sony 7.1 system.?
Also does anyone know anything about these two recievers? I have heard good things for both but the Sony is $100 cheaper than the Yamaha and it's 7.1.
Any help you can provide would be greatly appreciated, thanks.
Username: Thx_3417
Bournemouth, Dorset
United Kingdom
Post Number: 13
Matt,
Mate I like the Yamaha makes and models, and they have some nice THX ones as well, like as what follows
http://www.audioholics.com/productreviews/avhardware/Yamaha_RX-Z9p1.php
http://hometheater.about.com/od/audiocomponentreviews/fr/yamaharxv1500f.htm
I like this one below she beautiful, but it’s only an object, hell no she is a B***h form the depths of the abyss….
http://www.hometheatermag.com/receivers/104yam/
….save the money up just a little bit more this is no turkey!
Mate I’m running the old Kenwood KRF-X9050D THX select Dolby digital and DTS, if I where to change my AVR tomorrow I’ll go for this Yamaha RX-V2400,
Or the Kenwood
http://www.audiorevolution.com/equip/kenwoodvr5700/
Maybe a little over priced though…
Or why not this Kenwood a little down to earth in the price range
http://www.laaudiofile.com/vr8070.html
So have a read on the list I have sent you and purse…
…for one moment and say should I go left, or should I go right?
Give me some feedback
Ashley.
Thanks for the list. The problem is that i'm on a very limited budget and the moment and I'm pretty much stuck with recievers of a limited price range.
My main question is whether or not to use my old speakers as part of my new system, I assume the answer would be to use them, but I'm not sure.
Thanks again,
Matt
Username: Paul_ohstbucks
Post Number: 937
Why wouldnt you use them??
That should be the question. Use the KLHs as fronts, and go with a 7.1 setup if your room will allow. There are plenty of reasonably priced 7.1 receivers on the market.
good luck
Thanks, I was just making sure that it would be wise to add in two different speakers into a set designed to work with eachother. Like I said, I'm new to this, thanks for clearing that up.
Should I experiment to see if the KLH's sound better as fronts or as backs? Or will they most likely work best as fronts?
Thanks again,
Matt
Post Number: 958
Experimentation is what it's all about. Ideally, your largest speakers capable of the greatest output should be used as fronts because they carry the greatest workload and make the largest impact.
If HT is your interest, a good sub will also be an important component in the mix. Possibly even moreso than the fronts if 'big' sound is your thing.
Username: Thx_3417
Bournemouth, Dorset
United Kingdom
Post Number: 25
Hallo there, Matt.
If you can get hold of another matching one for the centre channel WOW is what you will be saying, and we won’t hear from you for weeks as you will be so deep, deep into the film.
So plan to get some new ones three matching ones for the screen channels
Bass is all so very heavy in the centre channel and if the centre channel is too small, or if you haven’t got matching loudspeakers the magic of home cinema is weak sounding.
And lost voicing will be pretty close and you will have to apply EQ to the screen channels as they will be in different parts of the room, the left and right will be against two room boundaries the back wall and the side wall, this adds a around 6db gain and the centre channel is only against one boundary the wall, and if you where too do and A&B test using a RTA and a sound level meter, you will see the differences between the sides and the centre playing say some dialogue or a sound effect in mono and sending it to the left centre and right of plan ole pink noise wideband.
Give the screen channels some thinking and if you are a die hard guy who like me likes cinema sound, and the home cinema should comply with the standards to the level that all matching loudspeakers, good bookshelf ones floor standing or the real McCoy if the room is bigger, enough to take them.
I’m getting away with just one big JBL 4645 THX cinema approved one that most of my friends say still can’t get over the size of it, WOW!
Matching fronts, yeses….
Username: Thx_3417
Bournemouth, Dorset
United Kingdom
Post Number: 26
Hallo there, Matt.
Take a look at this.
http://images.google.co.uk/imgres?imgurl=http://international.jbl.com/home/synth esis/images/products/small/S2MR.gif&imgrefurl=http://international.jbl.com/home/ synthesis/productlist.asp%3FSerId%3DSyn2&h=196&w=196&sz=11&tbnid=HzgoUk7sb4YJ:&t bnh=98&tbnw=98&hl=en&start=74&prev=/images%3Fq%3DJBL%2Bhome%2Bcinema%26start%3D6 0%26hl%3Den%26lr%3D%26sa%3DN
And if they are pried over the budget range, then there are other options,
http://images.google.co.uk/imgres?imgurl=http://www.villatheatre.com/photos/0301 23/030123-DSCN8565-175.JPG&imgrefurl=http://www.villatheatre.com/photos/BehindNo rthEdge.html&h=250&w=175&sz=25&tbnid=vixJHkkptLYJ:&tbnh=106&tbnw=74&hl=en&start= 1&prev=/images%3Fq%3DJBL%2Bbehind%2Bthe%2Bscreen%26hl%3Den%26lr%3D
Three of these WOW
http://images.google.co.uk/imgres?imgurl=http://www.expandore.com/product/JBL/LS R6332.jpg&imgrefurl=http://www.expandore.com/product/JBL/LSR6332.htm&h=153&w=110 &sz=16&tbnid=JuxdiEX6_7gJ:&tbnh=90&tbnw=65&hl=en&start=2&prev=/images%3Fq%3DJBL% 2Bbehind%2Bthe%2Bscreen%26hl%3Den%26lr%3D
Or three of these beauties
http://images.google.co.uk/imgres?imgurl=http://www.audioenz.co.nz/2004/images/a rchives/jbl_sva2100.jpg&imgrefurl=http://www.audioenz.co.nz/2004/archive_jbl-sva 2100.shtml&h=491&w=250&sz=17&tbnid=j2isI8_K-OgJ:&tbnh=126&tbnw=64&hl=en&start=7& prev=/images%3Fq%3DJBL%2BSVA%26hl%3Den%26lr%3D
Three JBL SVA 1500 nice
http://images.google.co.uk/imgres?imgurl=http://firek.free.fr/jbl_sva1500_face.j pg&imgrefurl=http://firek.free.fr/jbl_sva.html&h=459&w=160&sz=16&tbnid=iR5J9wBBG hUJ:&tbnh=123&tbnw=43&hl=en&start=12&prev=/images%3Fq%3DJBL%2BSVA%26hl%3Den%26lr %3D
And if you have seen Star Wars episode 3 revenge of the sith, just imagine hearing it towards the end of the year with JBL Jedi blasters and lightsabbers, chances are you heard it via JBL, and with 85% of cinemas using them in the film industry they are the choice of professionals.
Enjoy the force is, strong with JBL….
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through June 13, 2005 > New to home theatre. 5.1/6.1/7.1? [ « Previous ] [ Next » ]
