Thread: Green hue with compenent cables |
Unregistered guest |
| Posted on Saturday, May 21, 2005 - 11:04 pm: |
Just switched to component cables from RCA. I'm only using these with DVD. I am now get all dark scenes have a green tint. TV picture via RCA is OK. I have component from DVD to Receiver back to TV. |
New member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 5 Registered: May-05
| Posted on Sunday, May 22, 2005 - 01:26 am: |
Pkitch, hi there check the scart connection is plugged in nice and tightly, if the problem is still happening, undo the scart on both ends, if the wire or the pin connection as come undone solder it up, this will take only a few minutes to do. Good luck Ash…
Bronze Member Username: Philman
Richmond,
IN
Post Number: 93 Registered: Dec-04
| Posted on Monday, May 23, 2005 - 08:15 am: |
pkitch, In case you don't live across the great pond, (thus not having a clue about a scart connector) you might want to double check that your cable ends match the color indicated by the component input jack all the way from the DVD to the TV. I'll trust that you have component (R, G, B) connectors on all three. Also you could try going from DVD to TV directly and eliminate the reciever just for kicks. my 2¢
chesapeakegoody Unregistered guest |
| Posted on Monday, June 13, 2005 - 12:13 pm: |
I have a rear projection HDTV (55" Mit.) and JVC DVD player with component cables and I have the same green tint problem. I've checked all the connections. It is either the cable or DVD player's fault. If you figure this out, let me know! |
Bronze Member Username: Daedilus
Post Number: 49 Registered: Jun-05
| Posted on Monday, June 13, 2005 - 12:19 pm: |
Also make sure that your TV or monitor doesnt have a selection setting in the inputs menu that allows the component vid input to change formatts between RGB and component. Having this switched to RGB can also cause a green picture. |
Silver Member Username: Dmwiley
Post Number: 769 Registered: Feb-05
| Posted on Monday, June 13, 2005 - 01:38 pm: |
Pkitch, do you have a Samsung tv? |
Silver Member Username: Philman
Richmond,
IN
Post Number: 109 Registered: Dec-04
| Posted on Monday, June 13, 2005 - 01:47 pm: |
I'm pretty sure we're talking consumer, not industrial products here, so your DVD and TV are going to be Component Video. All three cables and connections must be good or you can get green tint. Since Component signals are made up of Luminance, and difference signals from Red and Blue (Y, R-Y, B-Y) the green signal is derived from the combination of the three signals. (R, G, B, previous post refer to cable sleeve colors) Component Video cables are almost always a type of COAX, if it has been pinched or severly bent it can effect the capacitance on one of the cables which has the affect of imbalancing the cable's frequency response. Hence, one signal gets attenuated causing the green tint. Sometimes, cheap cables can also do the same as they may be made of inferior materials, poor shielding, etc and not balanced between the three signals. If you can pick up a new cable or swap with someone, you can troubleshoot through process-of-elimination. |
Richmond,
IN
Post Number: 110 Registered: Dec-04
| Posted on Monday, June 13, 2005 - 01:49 pm: |
Sorry Dale, we seem to be hitting the same post at the same time. |
tookie7155 Unregistered guest |
| Posted on Sunday, July 24, 2005 - 08:32 pm: |
i had the same problem with green tint. it was the cable i replaced it and it went away |
New member Username: Loki69
Memphis,
Tn
Usa
Post Number: 3 Registered: Jul-05
| Posted on Sunday, July 31, 2005 - 10:50 pm: |
dont get upset at this comment but it happened to me very recently. after 3 days of forums searching and phone calls to manufactures. I found that my component cables were not firmly plugged into the device. (and i mean push hard.) its worth a try. good luck
| Posted on Wednesday, September 07, 2005 - 01:34 am: |
I'm having the same problem and pushing hard didn't work. tried two different cables - no luck. Problem exists with both pioneer dvd recorder and with motorola PVR. Picture is much better with RCA or s-Video cables. Any suggestions? |
Post Number: 3857 Registered: Dec-03
| Posted on Wednesday, September 07, 2005 - 11:03 am: |
check the integrity of your component cables. |
