Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through June 13, 2005 > Test DVD??
Author Thread: Test DVD??
kevinsky18
Is there a test DVD that one can buy that has sample music / sound effects to test ones surround sound system? I have DVD burner so if it can be bought and downloaded even better.
Username: Dmwiley
Post Number: 655
Digital Video Essentials.
Username: John_s
Columbus, Ohio
US
Post Number: 326
See
http://www.audioholics.com/techtips/setup/avhardware/DigitalVideoEssentialsDVDr. php
Username: Thx_3417
Bournemouth, Dorset
United Kingdom
Post Number: 8
kevinsky18,
There is also the DTS music and demonstration set-up disc, this I have used for many years now for setting up the sound very good as well, if you can get one though,
http://www.dtsonline.com/
they may be, able to help you out.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through June 13, 2005 > Test DVD?? [ « Previous ] [ Next » ]
