Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Sony HT-DDW660
Author Thread: Sony HT-DDW660
Username: Pwfd1613
Pinewood, South Carolina
Ok I have a Sony HT-DDW660 that I purchased about 2 months ago it worked fine until about a month ago when it started clipping the sound that was coming from my optical output which the source is my Sony PS2 but my Digital cable box which is connected through the digital output works flawless. I can not figure out if this is a problem with the receiver or if its as simple as a cable? anyone else have this problem? Please help, btw I purchased the cable around the same time of the home theater
Username: Hunter371
Smithtown, New York
As a guess, I would say it's something wrong with the PS2. I would check the ends of the fiber optic cable to make sure nothing is wrong with the delicate cable itself. Also, try using an analog setup with your PS2 and see if you hear clipping.
Username: Bomb
Rock Spring, GA
Post Number: 7
Is the Sony HT-DDW660 Home Theater System any good?
Username: Hunter371
Smithtown, New York
Post Number: 7
I myself own the HT-DDW670, the newer version of the 660, and I love it. Loud enough, good sub, no noticable distortion, enough inputs, and I bought it on sale for $180.
Snpbond
I also got the 670, its good, and loud, but if you turn it up 63+ and there is a quiet scene in the movie, youll hear a bit of static from the speakers, only to the close listener though, this can be fixed by turning the levels down to -2'ish
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Sony HT-DDW660 [ « Previous ] [ Next » ]
