Thread: Surround sound problem |
ryan 77 Unregistered guest |
| Posted on Wednesday, May 18, 2005 - 06:32 pm: |
hi, i just bought sur.sound setup with 4 speakers and an amp/sub box. i have /dvd/xbox/freeview/ all connected into a multi scart with the other end into the tv. the cable from the roof going into my tv. i have 2 (red & white) ports in tv which when i plug the corresponding colours in from the s.sound gives me sound in 2 speakers. how do i get the others to work? theres no where for these colour coded wires to go! i would like the s.sound to work whatever device is playing through tv. pls help thanks. oh the colours correspond to the position of the speaker eg centre, back |
| Posted on Thursday, May 19, 2005 - 05:06 am: |
have i not given enough infomation? please help!!! |
Check for Pro-logic Unregistered guest |
| Posted on Thursday, May 19, 2005 - 09:54 am: |
Ryan, unless the amp you have brought states that it can reproduce 'Dolby Pro-logic or Pro-logic 2', I don't think that you'll be able to get it to play in surround. At the moment, you are only sending LEFT and RIGHT info' to the amp, so it is only playing those two channels. |
