Thread: Wiring |
kpetersn90 Unregistered guest |
| Posted on Wednesday, May 18, 2005 - 03:20 pm: |
I had a question regarding hooking up my DVD, TV and digital cable box. If someone could tell me the best way to hook all these up I would appreciate it. Should I use all color difference component video cables or should I use those cables in conjunction with the S video cable and the coax video cable. Thanks for your help |
Silver Member Username: Dmwiley
Post Number: 637 Registered: Feb-05
| Posted on Wednesday, May 18, 2005 - 03:46 pm: |
Hard to abstractly answer these questions without information on connectivity options available on your set. You do not need to use component and S-video connections between particular devices. Component will give you a better picture. |
| Posted on Wednesday, May 18, 2005 - 04:37 pm: |
Hey Dale thanks for your quick response. Here's a little bit more info about my system, maybe you can help. I have a Sony LCD projection TV HDTV ready with S-video inputs, component inputs, HDMI input, optical input, I have a Denon AVR 2805 receiver with component input/output, optical, s video and coax, I have a Sony DVD player with DTS/Dolby with optical outputs, s-video, component outputs, coax and then I have A Scientific Atlantic HDTV digital cable receiver with HDMI output, s-video, component and coax. I want to run everything through my receiver if possible and If you can't tell already I'm a total amateur when it comes to this stuff, I appreciate all your help |
| Posted on Wednesday, May 18, 2005 - 04:43 pm: |
I apologize it's not coax its A/V cable that I meant to say |
