Thread: Questions about hooking up Home Theater |
Unregistered guest |
| Posted on Wednesday, May 04, 2005 - 04:34 pm: |
Hey guys, I have a question. I just brought a new tv from eBay. It's a Sanyo DS20930 20" for my bedroom. I read some good reviews about this tv so I bought it. I think this tv don't have a audio output. Is there anyway I can get a 5.1 surround sound speaker setup for this tv. I am also looking to hook up my Xbox, PS2, Cable TV, and DVD player to it. Is there anyway I can hook up all of these since this tv has only 2 RCA In ports? Also since I'm only a college student, is there any cheap 5.1 systems that you can recommend? Thanks. |
Post Number: 2993 Registered: Dec-03
| Posted on Thursday, May 05, 2005 - 11:54 am: |
Check out the speakers from fluance.com Great budget speakers. Do you have a budget for a receiver and speakers? |
Arthur Luo Unregistered guest |
| Posted on Thursday, May 05, 2005 - 04:24 pm: |
Maybe, depends on the cost but I don't have any audio out ports on my TV though... |
New member Username: Musicjam23
Post Number: 1 Registered: May-05
| Posted on Wednesday, May 11, 2005 - 02:07 am: |
Hey people's I have a KOSS KS5192 DIGITAL HOME VIDEO AND AUDIO ENTERTAINENT SYSTEM. I have a qustion that I need an answer to asap. WILL IT Work on my Television I got DVD's to work and the radio works but it will not work at the moment to where I can hear the television thru the speakers! |
Silver Member Username: Paul_ohstbucks
Post Number: 847 Registered: Jan-05
| Posted on Wednesday, May 11, 2005 - 10:10 am: |
Arthur, That doesnt matter. To be honest, you dont even want to use audio outs from your TV for surround because your tv will send a poor quality 2channel signal(at best)to your receiver. If you want 5.1 surround, you'll need to connect your DVD player(and other components) directly to your receiver via a digcoax or optical cable and completely leave your TV out of the loop. |
Post Number: 848 Registered: Jan-05
| Posted on Wednesday, May 11, 2005 - 10:12 am: |
Kenneth, If that's the case, you still need to connect a TV-audio source into your receiver. |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 271 Registered: Mar-05
| Posted on Wednesday, May 11, 2005 - 10:15 am: |
paul you must work from home too |
Post Number: 850 Registered: Jan-05
| Posted on Wednesday, May 11, 2005 - 10:33 am: |
LOL......yep. I'll never ever do the 'office thing' again. |
