Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through May 02, 2005 > Can I use a regular tuner amp with a ...
Author Thread: Can I use a regular tuner amp with a powered speaker system?
Username: Maakupoe
Hi all you knowledgeable people,
I wonder if you can help me. I'm considering buying the Earthquake Sound SN-51 speaker package. I see that it has a built-in 500W amplifier. But it doesn't come with a separate tuner, etc. Can I just plug a regular tuner-amp (that all of my sources plug into) into the SN-51, or is it going to blow up if I send an already-amped signal into the SN-51's amplifier? Thanks in advance.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through May 02, 2005 > Can I use a regular tuner amp with a ... [ « Previous ] [ Next » ]
