Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Custom Wire Harness
Author Thread: Custom Wire Harness
Electricly Chalanged
I am in the process of putting together a custom speaker wire harness for my new bose lifestyle system using monster speaker wire. My house is already wired with the monster cable down to a plate in the wall next to where the bass unit will sit. I would like to make the wire harness with the 5 RCA cables that plug into the bass unit. I have ordered the system and it will take a few weeks to come in so I don't have the original harness to go by.
What I would like to know is on the RCA plug what is the wire config? Center post (+ or -), and outer case (+ or -).
I know I could just flip the wires on the opposite end to match + or - but I'd like to keep it consistant.
Thank You
Bob
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Custom Wire Harness [ « Previous ] [ Next » ]
