Thread: NAD t743 problems |
New member Username: Major
Post Number: 5 Registered: Feb-04
| Posted on Friday, April 29, 2005 - 11:42 pm: |
My NAD t 743 is a little over a year old. Out of the blue, it will only produce sound intermittently with a DVD or CD and will not run the TV audio at all. When it does produce sound with the DVD or CD it is only on certain sound modes. Does anyone have any ideas why this is happening? After owning it for a little more than a year, I will extremely angry if it needs to be replaced. Thanks so much for your help. |
Post Number: 7 Registered: Feb-04
| Posted on Saturday, April 30, 2005 - 08:52 am: |
Never mind, solved. I think I just had some wiring problems with the wires touching. |
Post Number: 8 Registered: Feb-04
| Posted on Saturday, April 30, 2005 - 11:39 am: |
Strike that. Problem is back, I knew that was too good to be true, any suggestions? |
Silver Member Username: Paul_ohstbucks
Post Number: 689 Registered: Jan-05
| Posted on Saturday, April 30, 2005 - 12:06 pm: |
Apparently NAD uses faulty designs or has quality control issues, and I'd Steer clear of NAD. They seem to have mastered the art of building faulty components. If heard your plight 1,000 times from NAD owners. By contrast, you'll never heard of similar problems from owners of Pioneer, Yamaha, or Denon on this forum nor anywhere else. |
Post Number: 10 Registered: Feb-04
| Posted on Saturday, April 30, 2005 - 12:19 pm: |
Too late to steer clear. Any productive advice would be appreciated. Thanks. |
Post Number: 691 Registered: Jan-05
| Posted on Saturday, April 30, 2005 - 12:38 pm: |
Sorry major, Providing you havnt changed your connections recently, I'd drop it off at a local authorized service center to get tested. |
