Thread: Does any one have a hook up diagram for dvd/vcr combo with digital cable box??? |
rowdy1234 Unregistered guest |
| Posted on Monday, April 25, 2005 - 09:43 pm: |
Iam trying to hook up the following: sony home thearte system motarolla digital cable box samsung dvd/vcr combo sanusi 27in tv i thought i had it hooked up, but i only have surrond sound on dvd's and mtv. and a few select chanels with cartoons on them. can you give me a hook up diagram for audio and video that would allow surround on all the channels? i know nothing about this kind of stuff so go easy on me, i am super frustrated at this point!!!!!!!!!!!!!!!! |
Silver Member Username: Dirtfarmer
Alberta
Post Number: 603 Registered: May-04
| Posted on Monday, April 25, 2005 - 11:02 pm: |
try here Use this link to go directly to the discussion: http://forum.ecoustics.com/cgi-bin/bbs/show.pl?3/113395 |
| Posted on Monday, April 25, 2005 - 11:11 pm: |
i already did but do not know which diagram to use, plus i was told to start a new thread bucause no one would answer me there |
Alberta
Post Number: 604 Registered: May-04
| Posted on Monday, April 25, 2005 - 11:57 pm: |
yes i notice a guy posted thjat on the site i started, it true the site is geting big, alot bigger then i thought it would get, i post a bout all i could think of if you have a reciver for your stero, i would start there, and add all teh other thing to that the main chart post on start of the site i told you about should give you a good idea and if you notice a lot of chart tell teh same thing to use the reciver as the center point of everthing and as for the other guy, forget him his half right and half wrong, even if you created a new post, it does mean someone will answer, that the wrong part lol |
