Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Subwoofer connection problem
Author Thread: Subwoofer connection problem
Username: Timfore
Post Number: 10
I was told I could run rg6 coaxial in wall for my subwoofer. I did this and converted the coaxial connection to rca at a wallplate. Plugged the sub into 1 plate and a audio cable from the other into the sub connection of the receiver and I am hearing is a loud humming. Was it a bad idea to use the coaxial or am I doing something wrong?
Username: Dmwiley
Post Number: 499
In my experience, RG6 does an excellent job. Check the points where the cable is terminated and where it is connected into the wallplate. Poor connections will cause hum.
Username: Timfore
Post Number: 11
I used a screw on type coaxial connector. Do you think this could be the problem? Everything seems to fit ok
Username: Dmwiley
Post Number: 501
Possibly. Turn on the sub at low but audible volume level. Wiggle connections a bit to see if humming worsens or disappears.
Username: Grtone99
trying to reduce ohms on my amp
using a cerwin vega on a alpine 15r duel voice coiled.my amp only provides 1 set of wires.i need 2 for this sub.any suggestions?thanks
Username: Joe_c
Oakwood, Ga
Post Number: 220
do you know if it is an 8ohm or 4ohm speaker, if its the latter, series the wires like thishttp://www.jlaudio.com/tutorials/wiring/index.html#1dvcs if it is a dual 8 then either do the same or do thishttp://www.jlaudio.com/tutorials/wiring/index.html#1dvcp but that will put the ohms at 4 at the amp. Usually house amps are 6-8ohms. if you have two of these spkrs @ 8 ohms then run the series and then run both sets together at the amp.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Subwoofer connection problem [ « Previous ] [ Next » ]
