Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Wire run questions
Author Thread: Wire run questions
OK: I am setting up either a 5.1 or 6.1 system in my 17x19 basement. I am running the wires now. A couple questions, I hope you all can help me with:
1) Can I run 3 speaker wires together through the same set of holes that I drilled in the floor joists or will they interfere with each other?
2) Can I run speaker wire in the same holes as the cable tv coax cable or will this cause interference?
3) Can I run speaker wire, 3 component video cable, and tv coax in the same holes, or does this cause interference?
thanks, Doug
Username: Joe_c
Oakwood, Ga
Post Number: 141
1) yes no problem
2) no problem either unless the video cable is not shielded which most are.
3) sure although unless you have sheilded spkr cable I would run speaker sep anyway you probably wouldn't hear anything but you might get unwanted artifacts on the screen
Regarding #2, how can I tell if the coax cable is shielded? It has a black outer soft shell. Inside that is a layer that looks like thin aluminum foil. Inside that is some white soft insulation, then in the middle is the copper wire.
Username: Joe_c
Oakwood, Ga
Post Number: 142
it is
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 14, 2005 > Wire run questions [ « Previous ] [ Next » ]
