Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Sony DAV-S300 not playing DVDs
Author Thread: Sony DAV-S300 not playing DVDs
Username: Jan_dhr
My DVD player (Sony DAV-S300) does not play DVDs any more though it still plays music CDs. It either says 'No disk' or displays error code "00:13". What is happening here? Why does it play CDs but not DVDs?
morti
I have the same problem. I thought it might be the new encryption that is being used, but it won't play old DVDs either.
yuet
same problem with mine. The warranty period was just over a month ago.
Username: Jayluv76
I have the same problem with mine. I contacted Sony and they say the DVD part is going bad. So I put the s300 on ebay and bought a Yamaha 5750, Athena Micra6, two Athena AS-F2's, Athena AS-R1S-1, and a D-Link DSM-320RD to play my dvds (and do other things of course). After all, it is time for an upgrade don't ya think?
Once you get that error code (13:00) it's only a matter of time until it wont read a single DVD. According to Sony anyway.
Username: Daedilus
Post Number: 181
You have been informed by the manufacturer that the unit is bad, and you are attempting to sell it on Ebay?
Do the world a favor and choke on a $100 bill. People like you should be tied to a stake at low tide for crabs to pick apart at high tide.
Username: Jayluv76
Michael, If someone wants it for parts like the listing says they can pay to have it.
Maybe before you go passing judgement on someone you should try to get more information, a$$.
Username: Daedilus
Post Number: 183
Then he should have said "for parts" in his post.
8 extra letters and he could have avoided my ire.
LonewolfNS
if I kill an electronic divice I can usually pull another working one out of sombody's garbage on Monday night anyway... welcome to the throw-away era
Hi,
Could some one to help me finding the region free code for stand aloneDVP player SONY DAV S300?
Thanks for your support
Mihai
Just wondering if someone could help me out with my Sony DAV-S300 as well!! I tried one code but didnt seem to work. That is if there is a region free code for it
any ideas would be greatly appreciated
Bec
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Sony DAV-S300 not playing DVDs [ « Previous ] [ Next » ]
